Membrane structures
  • Membrane structures
    Dears,
    I am new one with RFEM. Could anyone help me to instruct how to model this structure.
    The edges connection (holes and cables) of the membrane can be model in RFEM?
    I appreciate to your helps.
    Thanks.
    Any updates?
    Zuletzt geändert von Witerestich; 02.11.2023, 02:00.
      I would divide the calculation into two parts. First, I would verify the membrane and the steel structure in the complete system. I would connect the membrane to the edge member over the whole length.
      This webinar shows how to proceed:
      In a second model, I would take a closer look at the details with the openings and the cables. It might be enough to model just a few openings and cables. The curve of the membrane can probably be neglected.
      The advantage of this approach is that it is not necessary to mesh the boundaries as finely as when the openings are taken into account in the overall model.
        Has been updated
          How does separating the structural analysis of a tensile membrane structure into two distinct models - one for the overall system and another for detailed elements - impact the efficiency and accuracy of the design process?
            I don't think that can be said in general terms. It depends on the type and size of the model.
