RFEM 6. Imperfection case based in a buckling mode.
  • RFEM 6. Imperfection case based in a buckling mode.
    When creating an imperfection case based in a buckling mode, why do we have to define the scaling direction? The bucking mode is already a deformation.
Ansichten: 106
Größe: 27,2 KB
    Hello, usually you will use this option:
    Imperfection
    Then, the deformation figure will be scaled as it was in RFEM 5.
    Scaling in only one specific direction is an additional option in RFEM 6.
      Ok, thank you!
        I don’t have this add-on in my RFEM 5 license.
        If I were to use this option with 7GDL, what would be the procedure?
        What I understand is the following:
        1. Activate the add-ons Stability and 7GDL.
        2. Stability analysis.
        3. Imperfection case > Type “Bucking mode” > Source “Select Load Combination”
        But there are a lot of load combinations and modes. I have seen a webinar but the explanation is only for a member and 1 load case.
        And also, I don’t know how to apply this in a real case. And there is this window that I don’t know how it works.
Ansichten: 101
Größe: 43,0 KB
          Hello, this webinar, starting at minute 50, shows how to apply 7DOF analysis to slightly larger models.
          This window shows in which LCs the IC 5 is used.
          Example:
          I have defined an IC.
          Imperfection Case
          Imperfection Case
          I select the IC 1 in the CO 1.
          Load Combination
          The CO 1 appears in the list.
          Imperfection Case
            Thanks Frank,
            I don’t know why I have the assignment different to yours. I’ll contact the Spanish support.
            I’ve watched the webinar, thanks, it would be nice to have the a webinar with the next steps: assignment of imperfections and analysis. This is so new for me.
            Helena
              Hallo Helena, I will forward your wish to Andreas Hörold. He organizes the webinars.
