Rhino Grasshopper to RSTAB export?
  • Rhino Grasshopper to RSTAB export?
    I am trying to export data (in this case points coordinates) from Rhino's generative algorithm plug-in Grasshopper to RSTAB. But for some reason I can not import the .xls file I got from Grasshopper. To be precise - I can import it, but nothing happens after the Importing, no imported nodes appear.
    Can you please tell me what is wrong?
    I attached the .xls Excel file in the .zip attachment
    Thank you.
    AW: Rhino Grasshopper to RSTAB export?
    Hi Geoge,
    when handing structures over from GH to Rstab/Rfem you should consider using the RS-Com/RF-Com interface, a VB based scripting language to interact which allowsyou to directly write/read/calculate out of other applications like GH and a VB component.
    The beginning to handle that way is a little hard but then the exchange works quite good.
    You can have a look here:
    http://www.dlubal.de/rs-com-7xx.aspx
    Best
    Thorsten
      HI Thorsten,
      Thank you for the link and advice.
      A bit rarely somebody replies in here to us - nonGerman speaking users.
      I know, I already seen some of your screenshots on Grasshopper forum. Great work!
      But that requires programming knowledge.
      I solved my problem, by exporting the .xls file first and then importing it back:
      https://www.dlubal.de/forums/showthr...=1152#post1152
      Zuletzt geändert von george; 30.01.2013, 12:44.
