3d hinged joint releases?
  • 3d hinged joint releases?
    Is there a way to make all members in a double layer space frame, to became hinged (to have hinged nodes)?
    I intend to use the 4 hinged supports. Here is an example of a space frame:
    Can I just select all members, then righ-click-> Member-> Edit, and then in Member Release define the
    following releases:
    Member start: NNN NYY (My, Mz checked)
    Member end: NNN YYY (Mt, My, Mz checked)
    Thank you.
    AW: 3d hinged joint releases?
    Any help on this please?
    Thank you.
