Hi,
I'm dealing with a portal frame with a built-up cross-section made of two C channels oriented back to back (see attached picture), made of cold-formed steel. I'm wondering, how does this not connected cross-section need to be modeled in the Shape-Thin?
Can RFEM use those results in either check of the cross-section and member in the RF-STEEL EC3 module?
One more thing that I noticed is when I run the calculation for the cross-sections, when the c/t parts and effective cross-section properties module is activated, in the printout report, in the part of section classification for the limit values for section class (λi) there are zeroes, and the cross-section is classified as a class 1 which is not correct.
Kind regards,
Jovan
Kind regards,
Jovan
