Iteration displacement limit
  • Iteration displacement limit
    I'm performing a moving load analysis along a cable (length 100 m), i.e. with a lot of load cases.
    Results are OK, but the convergence speed is very slow: it seems that dlubal limits the displacement for iteration to 200 mm (see image attached), even if there is NO particular convergence problem.
    Is it possible to increase this iteration increment limit (in order to reduce the number of iterations)?
    Regards
    Andy
    Zuletzt geändert von andy; 10.07.2021, 09:52.
    Hello Andy,
    have you tried if the precision settings have any influence?
    Precision Settings
    A tip would be to try the solver "Dynamic Relaxation". For cable structures it is sometimes very fast.
    Dynamic Relaxation
      Hello Frank,
      the convergence plot for a combination requires 27 iterations, moslty limited to 200 mm for each step.
Ansichten: 114
Größe: 39,2 KB
      If I relax tolerances
Ansichten: 123
Größe: 18,1 KB
      the benefit is just the reduction of one iteration, being convergence limits less stringent. But I'm not asking for less stringent limits: the problem I observe is that during convergence most iterations are limited to a displacement limit / per iteration (200 mm) that slows the solution. Is this limit "hardcoded" in the solver?
Ansichten: 120
Größe: 38,7 KB
      Dynamic relaxation is much slower (and takes 15000 iterations)
Ansichten: 120
Größe: 32,3 KB
      Thank you
      Andy
        Hello Andy,
        I am not aware of any settings to change the displacement per iteration. But maybe the value depends on other parameters. I would like to investigate this in more detail. Can you please attach the file for this purpose.
          Hello Frank,
          here ( cable0.zip ) is a minimal input file. Please change the filename to "cable0.rfx" in order to open directly with RFEM.
          Best,
          Andy
            Hello Andy,
            I have taken a closer look at the problem. The deformation limit is hard coded and there is no way to influence it. It also does not depend on the size of the model.
            The Dynamic Releaxation in attached example takes a time slightly twice as long as the Newton-Raphson solver.
              Thank you Frank,
              may I suggest to improve this "hardcoded" limit to be at least model-size dependent (200 mm for a small frame is a "huge displacement", whereas on a big cable structure is a little displacement) or better, to expose it, for instance in the menu "Change standard settings"?
              Yours sincerely
              Andy
