I had to install the following packages updates:
Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.28.29914
Microsoft Visual C++ 2015-2019 Redistributable (x86) - 14.28.29914
Just before this update I was able to perform "direct export to tekla". After this installation (and system reboot), the export function is no more working: in tekla I don't get any output.
In the export log I don't see any error (see below).
Any suggestion?
Thanks in advance
Andy
Export_NET_RFEM_5.25_64.log:
10:04:20 - 25/05/2021 - RELEASE
10:04:20 - C:\Program Files (x86)\Common Files\Dlubal\ImportExport\RX-Common.NET\RX-ImpExpApp.exe
10:04:21 - Setting language: lngEnu
10:04:21 - Setting culture info: en
10:04:21 - Format: RxFormatTekla_NET
10:04:21 - Tekla version detected: T2020_0
10:04:21 - Loading assembly: C:\Program Files (x86)\Common Files\Dlubal\ImportExport\RX-Common.NET\RX-Tekla-2020.0.NET.dll
10:04:21 - Config.ReadConfig() - beg
10:04:21 - Config.ReadConfig() - end
10:04:21 - C:\Program Files (x86)\Common Files\Dlubal\ImportExport\RX-Common.NET\RX-Tekla-2020.0.NET.dll
10:04:21 - C:\WINDOWS\assembly\GAC_64\Dlubal.RFEM3\3.4.0.0__2 168830b90cb4fa2\Dlubal.RFEM3.dll - 3.4.0.0 (RFEM_3_4)
10:04:21 - C:\WINDOWS\assembly\GAC_64\Dlubal.RSTAB6\2.3.0.0__ fea8abdc389fb11c\Dlubal.RSTAB6.dll - 2.3.0.0 (RSTAB_2_3)
10:04:21 - 10:04:21 - RX-Tekla-2020.0.NET.dll build time: 2020.0.7614.21346 = 05.11.2020 11:51:32
10:04:21 - 10:04:21 - Connecting to server...
10:04:21 - 10:04:21 - done
10:04:21 - 10:04:21 - Connected to server: (RFEM 5.25.02.158703)
10:04:21 - Convert file: C:\Users\Public\Documents\Dlubal\ImportExport\Conv ersionFile_Material.txt - Rules read: 0
10:04:21 - Convert file: C:\Users\Public\Documents\Dlubal\ImportExport\Conv ersionFile_CrossSection.txt - Rules read: 1
10:04:21 - 10:04:21 - Locking license...
10:04:21 - App.ConnectToServer().rfGetDatabaseCrSc() - beg
10:04:21 - App.ConnectToServer().rfGetDatabaseCrSc() - end
10:04:21 - App.EnableSelections(...) - beg
10:04:21 - App.EnableSelections(...) - end
10:04:21 - 10:04:21 - Reading nodes... (11)
10:04:21 - 10:04:21 - Reading lines... (11)
10:04:21 - 10:04:21 - Reading materials... (3)
10:04:21 - 10:04:21 - Reading surfaces... (1)
10:04:21 - 10:04:21 - Reading nodal supports... (1)
10:04:22 - 10:04:22 - done
10:04:22 - 10:04:22 - Reading cross-sections... (4)
10:04:22 - 10:04:22 - Reading member hinges... (1)
10:04:22 - 10:04:22 - Reading members... (11)
10:04:28 - 10:04:28 - Mirroring axis: Y
10:04:28 - 10:04:28 - Mirroring axis: Z
10:04:28 - 10:04:28 - Smallest value of coordinates: (0., -6., 0.) meters
10:04:28 - 10:04:28 - Greatest value of coordinates: (11., 5., 3.) meters
10:04:29 - 10:04:29 - Size of structure: (11., 11., 3.) meters
10:04:29 - 10:04:29 - Reading member's result... (350)
10:04:29 - 10:04:29 - done
10:04:29 - 10:04:29 - Unlocking license...
10:04:29 - Closing log file
Any suggestion?
Thanks in advance
Andy
