I have a little difficulty in rfem.
I am trying to apply a load from the self-weight of a concrete slab (surface) to steel beams [primary and secondary].
I set the surface, edit it material and thickness. But after calculating from self-weight, I can see that the weight of the concrete surface is not taken into account correctly.
Found out that it is possible to impose load through the "From area loads to member loads via planes", but its not what I need. Also try to use different Member Type such as "Beam", "Rigid", "Rib...", "Compression" and "Result Beam" - so it doesnt help. Try to support surfece and enter eccentricity - doesnt help me too. How to transfer self-weight of a concrete slab to steel beams correctly. Thank you.
