Variable cross section
  • Variable cross section
    Hi, Im trying to modelate some variable cross section columns, but I want the modeled in this pic instead of the "symetric" one that Dlubal creates when you put a different section at ini/end.
    Thanks
    Hello.
    The cross section type at the beginning and at the end must be the same. I think that's your problem.
Ansichten: 238
Größe: 31,1 KB
    I have attached the sample file.
      Hi Frank, thank for your response.
      I refer that one face of the column must be completely vertical.
      Once at home I will attach an example.
        Hi again!
        As I said, I have an example of what Im looking for (Revit picture), instead of what I have (RFEM picture).
        Tried with eccentricity but the results wasnt good.
        Any ideas?
        Thanks
          Hello. The easiest way is to move the top node a bit to the right.
            Okey, thanks for the solution
            Greetings
