RFEM node numbering conventions for solid elements
  • RFEM node numbering conventions for solid elements
    I'm writing a translator (from RFEM to lsdyna). I would need to know the nodal numbering (internal connectivity) of the solid elements (tetrahedron, prism, pyramid) in order to map correctly to the LSDYNA convention.
    I see in the RFEM manual that the internal numbering is shown only for the hexahedral element [1], and for the other elements a document is cited [13]. Is it available?
    Thanks in advance
    Tiya.
    [1] https://www.dlubal.com/en/downloads-.../02/01#1024219
    "The following 3D elements are implemented in RFEM: tetrahedron, pentahedron (prism, pyramid), and hexahedron. For detailed information about applied elements and matrices, see [13]. Corresponding documentation can be requested from Dlubal Software."
    [13] I. Sevčík. 3D Finite Elements with Rotational Degrees of Freedom. FEM Consulting s.r.o, Brno.
    Hello Tiye, Sorry for the long delay. Here is the link to the document:
    http://extranet.dlubal.com/?file=SEV....r.o.,Brno.pdf
    Frank
      Thank you Frank,
      the document contains the info I need.
      Tiya
